跳转到主内容
MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换
你所需要的
  1. MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换, 底部盖板: 步骤 1 中的图像 1,1
    • 取出固定Macbook Pro底壳的P5梅花螺丝,如下:
    • 8颗3.1mm螺丝
    • 两颗2.3mm螺丝
  2. MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换: 步骤 2 中的图像 1,2 MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换: 步骤 2 中的图像 2,2
    • 从屏幕转轴一侧的边缘抬起,把底部盖板从MacBook Pro上抬起来。
  3. MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换: 步骤 3 中的图像 1,3 MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换: 步骤 3 中的图像 2,3 MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换: 步骤 3 中的图像 3,3
    • 底部盖板上有两个塑料夹子(红色),在上面的箱子里卡扣(橙色)可以装进塑料夹子。
    • 在重新组装过程中,轻轻地将盖板的中心推到它的两个塑料夹上。
结论
要重新组装你的设备,请按相反顺序执行这些指令。
33等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
6条评论
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - 回复
You need the recommended one for the lid an a torx T5 for the screws inside
Oros -
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - 回复
I've had the back off my 2015 15" Retina MBP a few times, without any issues. I bequeathed it to my wife and now without warning there are several screws missing. I don't understand what happened, how can this be? (No, she didn't remove them just to prank me!)
Are new screws likely to stay in place, or is it more likely the screw sockets are damaged or stripped?
groblewis - 回复
I would try some loctite. The screws on mine had a small amount of the "green" version
Richard Peach -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 104
过去 30 天: 379
总计 62,309
