本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the gray plastic upper case clips that secure the upper case above the optical drive opening.
你所需要的
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
4等其他人完成本指南。
