当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
The screws are captive to the metal memory cover.
When replacing the battery casing, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
The hard drive goes back into its compartment with the label facing down.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
