本指南有最近更改,您可查看未经巡查的最新版本。
简介
Corrosion? Bent pins? Whatever the problem, use this guide to replace your MacBook battery's connection to the logic board.
你所需要的
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
25等其他人完成本指南。
2条评论
My rev 1,1 white Macbook was missing the spacer.
So was mine. Also make note for comparison, the Apple Service Source manual states that the I/O Panel needs to be removed prior to removing the connector - happily, according to iRobot, you don’t have to.
dlcatftwin - 回复
