本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a broken upper case cable.
你所需要的
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Carefully peel the upper case cable off the adhesive securing it to the upper case.
32等其他人完成本指南。
一条评论
I’m in need of this MacBook a1181 keyboard and trackpad connector flex. Just identical to the one they are using in the pictures give demo.
Rahbar Ali - 回复
