跳转到主内容
加入维修社区 - 创建账户
MacBook Core 2 Duo Replacing the top board
    1. MacBook Core 2 Duo Replacing the top board, Top board: 步骤 1 中的图像 1,1
      • Please remove the following three screws:
      • One Phillips # 000 screw (screw head: diameter 5 mm, thickness 0.75 mm) of 11 mm in length in the middle of the case is one
      • Two Phillips # 000 screws (screw head: diameter 5 mm, thickness 0.75 mm) with a length of 14.5 mm are two
      • If the screw will get stuck to the case, you can remove the screw by sticking with a magnetic driver.
      • The shortest screw among the three comes in the middle.
      询问修复机器人
      添加评论
    2. MacBook Core 2 Duo Replacing the top board: 步骤 2 中的图像 1,1
      • Take out the battery and the 3 screws inside the battery compartment.
      • One 3mm long phillips head #0 screw (Screw diameter: 2.75mm)
      • On either side there are two 4mm long Phillips head #0 screws. (Screw head diameter is 2.27mm)
      询问修复机器人
      添加评论
    3. MacBook Core 2 Duo Replacing the top board: 步骤 3 中的图像 1,1
      • Please remove the following two screws at both ends of the partition on the right side of the battery. (The screw closer to the battery connector is only fixing the battery connector, so it is not necessary to remove it.)
      • Two Phillips # 000 screws (screw head: diameter 4 mm, thickness 0.5 mm) with a length of 6.25 mm are two
      询问修复机器人
      添加评论
    4. MacBook Core 2 Duo Replacing the top board: 步骤 4 中的图像 1,1
      • Please remove the four screws indicated by the red circle of the image on the partition of the battery on the front side of the main unit. It is the 2nd, 4th, 7th, 9th screw from the left.
      • Four Phillips # 000 screws (screw head: 4 mm diameter, 0.4 mm thickness) with a length of 3.25 mm
      询问修复机器人
      添加评论
    5. MacBook Core 2 Duo Replacing the top board: 步骤 5 中的图像 1,1
      • Please remove the following four screws on the back side of the computer:
      • The long screws are inside and the short screws are outside both ends.
      • There are two Phillips # 00 screws (shank dimension: 2.2 mm in diameter, 2 mm in length) (screw head: 3.2 mm in diameter, 0.5 mm in thickness) with a long 11 mm shank
      • There are two Phillips # 00 screws (shank dimension: 2 mm in diameter, 3.75 mm in length) (screw head: 3.2 mm in diameter, 0.5 mm in thickness) with a shank of 7.25 mm in length
      询问修复机器人
      添加评论
    6. MacBook Core 2 Duo Replacing the top board: 步骤 6 中的图像 1,1
      • Please remove the two screws on the optical drive side of the computer.
      • Phillips # 00 screw with shank of 5.2 mm in length (Shank dimensions: diameter 2.3 mm, length 3.5 mm) (screw head: diameter 3.2 mm, thickness 5 mm)
      • The same screw on the opposite side of the optical drive is the decorative so you do not have to remove it.
      询问修复机器人
      添加评论
    7. MacBook Core 2 Duo Replacing the top board: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      iFixit Opening Tool
      $5.95
      • Since the keyboard and the track pad of the top board are connected with the logic board with the ribbon cable, please never forcibly pull out. The ribbon cable may be torn down.
      • Let's detach the top board on the principle of lever (lever) so that it goes around from the screen side to the front side of the computer. If you use the plastic opening tool or a stiff guitar pick, you can easily remove it.
      • As the top of the optical drive top seems to stick together, please put a guitar pick etc. on both sides of the optical drive that is not sticking first and remove the top board with a lever.
      • After removing the work, the four gray plastic clips holding the keyboard may be disengaged, but please do not rush. There is a part where you put the clip in the corner of CD drive periphery right side corner and there is no problem if you slide the clip into it and set it there.
      添加评论
    8. MacBook Core 2 Duo Replacing the top board: 步骤 8 中的图像 1,3 MacBook Core 2 Duo Replacing the top board: 步骤 8 中的图像 2,3 MacBook Core 2 Duo Replacing the top board: 步骤 8 中的图像 3,3
      • While lifting the top board, please pull the black tab on the connector part of the silver cable upwards and remove the connector.
      • If there is no black tab it is possible to remove the connector from the connector housing by using the spatger with the lever principle.Because this connector is long, please be sure to remove it straight up.
      • Even if you disconnected the cable attached to the top board when removing the top board, please be assured that iFixit sells the cables individually. There is an exchange guide, it can do easily.
      • How about trying as an opportunity to remove dust, hair, etc while removing the top board? The best is to use a can containing compressed air. If you do it with a solid brush made of building materials (using common animal hair), static electricity will be generated and you can destroy your computer.
      • In reassembling, please confirm that the four gray plastic clips are on the optical drive side of the keyboard. (Please refer to the second image.) Please firmly attach the clip so that the keyboard is securely fixed.
      • To ease the reassembly process, it is better to clip the clip part. Please note that doing with a strong force may cause damage.
      • (Translator's comment) Since it will not be fixed unless you attach it with a strong force when fixing the keyboard, the insertion opening of the optical drive may be distorted with a strong force.
      • There is no worry about being distorted if you put half of the disc such as a DVD and the credit card etc which you no longer need into the insertion opening in half.
      询问修复机器人
      添加评论
结论
To assemble your device, please follow these steps in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
由衷感谢以下译者:
jp en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Uhucream
于10/04/15注册
827 声望
创作了2篇指南
团队
Japanese Translators Japanese Translators 的会员
Community
6 名成员
创作了16篇指南
2指南评论
This is a really useful wordle unlimited guide mainly because of the large number of screws you will see during disassembly. Only the screws mentioned need be removed but, without the guide, there are many more that look like they might need to come out. Thanks.
Dorathy Frazer - 回复 分享
wordle online is a sport that's performed as soon as a day and may be performed by way of an internet browser. Gamers need to guess a thriller five-letter phrase, often known as the “wordle” in six makes an attempt. Wordle was created by Reddit software program engineer Josh Wardle, who invented it for his companion, who likes phrase video games. It was a success amongst his family and friends so in October final 12 months he determined to check the waters on-line, however it was sluggish to take off.
hạnh trần - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 55
总计 1,714
