简介
The rear panel of your display assembly.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 4 screws from the back of the computer:
The longer screws go on the inside, shorter screws on the outside.
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
While holding up the upper case, pull up the black tab of the silver cable away from its connector.
While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
Two 3 mm Phillips near the right speaker.
One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
Remove the following 2 screws from the right hinge mount:
One 6 mm Phillips on the left side of the hinge mount.
One 10 mm Phillips on the right side of the hinge mount.
For Santa Rosa/Penryn models, see second picture and remove:
One 3 mm smalller diameter Phillips on the far left.
One 5.2 mm larger diameter 4.2 mm head Phillips in the middle.
One 10 mm Phillips from the far right.
Lift the right hinge mount with the small plastic piece out of the computer.
Hold the display with one hand while removing the screws from the left hinge mount.
Remove the following 3 screws from the left hinge mount:
One 7.2 mm smaller diameter Phillips from the right side.
One 5.2 mm larger diameter Phillips from the middle.
One 10 mm Phillips from the left side.
Lift the left hinge mount with plastic piece out of the computer.
Check that the cables on the right are not trapped under other cables.
Use a thin plastic card to release the tabs holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
Remove the small piece of foam tape stuck down above each of the bezel covers.
Remove the three 3.2 mm Phillips screws securing the right clutch hinge to the rear display bezel.
Remove the display inverter and its attached cable from the rear display bezel.
10等其他人完成本指南。
一条评论
This was a great guide. Very clear and accurate directions. The only thing I would add, is take careful note how the wifi and display cables are routed from the display to main logic board when you do the disassembly so that you can have them follow the same path when you put things back together.
Thanks for a great guide!
