跳转到主内容
加入维修社区 - 创建账户
MacBook Core 2 Duo RAM cover replacement
你所需要的
  1. MacBook Core 2 Duo RAM cover replacement, RAM cover: 步骤 1 中的图像 1,1
    • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
    • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
    • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
    询问修复机器人
    添加评论
  2. MacBook Core 2 Duo RAM cover replacement: 步骤 2 中的图像 1,1
    • Pull the L-shaped RAM cover towards you and remove it from the laptop.
    添加评论
结论
To reassemble your device, follow these steps in reverse order.
取消:我没有完成这个指南。
2等其他人完成本指南。
由衷感谢以下译者:
jp en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Uhucream
于10/04/15注册
797 声望
创作了2篇指南
团队
Japanese Translators Japanese Translators 的会员
Community
6 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 80
总计 1,910
