跳转到主内容
加入维修社区 - 创建账户
MacBook Core 2 Duo Left Hinge Mount Replacement
浏览量: 1.9万
浏览统计数据:
过去24小时
过去 7 天:
22
过去 30 天:
97
总计
18,589
评论: 107
106 comments on steps, 1 guide comment.
Go to guide comments
已完成: 12
12 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 2
2 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 没有估计
难度: 中等
Connects the hinges to the case.
你所需要的
配件
工具
    1. MacBook Core 2 Duo Left Hinge Mount Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      添加评论
    2. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 2 中的图像 1,1
      • Lift the battery out of the computer.
      添加评论
    1. MacBook Core 2 Duo Left Hinge Mount Replacement, Memory Cover: 步骤 3 中的图像 1,1
      • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover so you cannot lose them.
      • Using The Flexible Extension sold by iFixit will help with this step.
      添加评论
    2. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 4 中的图像 1,1
      • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
      • Lift the memory cover up and out of the computer.
      添加评论
    1. MacBook Core 2 Duo Left Hinge Mount Replacement, Upper Case: 步骤 5 中的图像 1,1
      • Remove the following 3 screws:
      • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
      • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle of the lower case.
      添加评论
    2. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 6 中的图像 1,1
      • Take extra caution with these screws as they can strip easily!
      • You could use a flexible extension to minimize stripping.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
      • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
      添加评论
    3. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 7 中的图像 1,1
      • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
      添加评论
    4. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 8 中的图像 1,1
      • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
      • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
      添加评论
    5. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 9 中的图像 1,1
      • Remove the following 4 screws from the back of the computer:
      • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
      添加评论
    6. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 10 中的图像 1,1
      • Remove the two Phillips screws from the optical drive (right) side of the computer:
      • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • It is not necessary to remove the similar screws on the ports (left) side of the computer.
      添加评论
    7. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 11 中的图像 1,1
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
      • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
      • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
      • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
      添加评论
    8. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 12 中的图像 1,3 MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 12 中的图像 2,3 MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 12 中的图像 3,3
      • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
      • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
      • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
      添加评论
    1. MacBook Core 2 Duo Left Hinge Mount Replacement, Left Hinge Mount: 步骤 13 中的图像 1,1
      • Remove the following 3 screws from the left hinge mount:
      • One 6 mm smaller diameter Phillips from the right side.
      • One 6 mm larger diameter Phillips from the middle.
      • One 10 mm Phillips from the left side.
      • Lift the hinge mount and attached plastic dust cover out of the computer.
      询问修复机器人
      添加评论
    2. MacBook Core 2 Duo Left Hinge Mount Replacement: 步骤 14 中的图像 1,1
      • Slide the plastic dust cover out of its slot in the left hinge mount.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了632篇指南
1指南评论
You have helped me a lot from this very detailed and detailed tutorial, I did it, thank you very much. I always follow the tutorials, please keep updating, thanks a lot. random street view
Hebe Lee - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 97
总计 18,589
