简介
Use this guide to replace a broken inverter cable.
你所需要的
Lift the battery out of the computer.
I just replaced the battery as indicated (with a iFixit part), but the computer says there is no battery connected, even after letting the power plug in for more than one hour.
I think I found the way to have the new battery to charge!!!!!
See: https://www.youtube.com/watch?v=jRYIMDQx....
Essentially, you have to follow a very precise order: 1/shut down the computer, 2/take off the magsafe connector, 3/remove the old battery, 4/put back the magsafe connector, 5/put the new battery, 6/power on, each time leaving a few seconds in between.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Lay the screws out in a ”timeline” like a circle, Then when you reassemble just start from the end of the “timeline”
The screws have to unscrewing positions, first they unscrew from the whole body BUT if you move the lid without entirely removing the screws, they will remain attached to the lid. This I find much more recomendable!
Wytchkraft - 回复
What size screwdriver
Edward: Philips 000
Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
Lift the memory cover up and out of the computer.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
来自 ryan64 的话:
I couldn't get the top two 11mm screws to come out, even with a magnetized driver. When I tried to keep unscrewing them, they clicked like they were spring mounted, and I didn't have any trouble leaving them in and continuing on.
I use a strong magnet to pull the screws out of their socket.
You need to replace the shorter middle screw first, otherwise it won't tighten later since it won't quite reach the bottom.
for me this was the hardest part especially the two 14.5mm that dint want to come out. keep turning the screw and slightly pressing the case down, once the screw is a little use try using finger, screw and a non metallic point to try to push them out. they arent tight but they are very hard to unscrew i almost gave up, but believe me they come out with patience
Remove the following 3 screws from the rear wall of the battery compartment:
One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
On this step, I encountered a problem. The middle screw was screwed in very very tightly. As a result, I ended up stripping the screw despite being very careful. I tried to use a wire cutter to remove the screw, but that did not work. I actually ended up using the wirecutter to cut the bracket off, leaving the screw screwed in. This did not affect anything. I am typing off of my replace macbook top case right now.
The point is, BE CAREFUL! but if something does go wrong, don't fret. There are solutions.
On a Macbook I just tore down, I found that in this step, the 4mm screw was on the left, not the right. I thought maybe someone else had it apart before and accidentally switched them so in staying true to these instructions I tried to reassemble with the 4mm screw on the right. I found it would not go all the way in. I ended up putting it back together with the 2-3mm screws on the right and the 1-4mm screw on the left.
I didn't look closely at these screws when I took it apart, but when I went to put it back together (two weeks later) I found I had two longer (4mm?) screws, and one short one. So I put the longer ones in the two end spots, the short one in the middle; they all seemed to go in okay. (Maybe the screws got changed around the last time the cracked top case was replaced, when the MB was in the Apple shop under warranty last year.)
Me too. I had two longer 4mm screws here, and one 3mm screw. And I didn't pay attention to what holes each screw came out of. I put them back in a random order and it seems fine.
Thomas -
My early 2008 MacBook was the same. 2 x 4mm in the outer and 1 x 3mm in the centre.
Ernie K -
You need to replace the shorter middle screw first, otherwise it won't tighten later.
I needed a tweezers here. These screws are tiny!
If you lose one you may have to remove the RAM (by pulling the appropriate lever) and gently slide out the screw.
oh thanks I thought the screw was lost forever
To confirm what HandyMac and colmcostelloe found, some MacBooks have one 3mm and two 4mm screws in the rear wall of the battery compartment. On the one I worked on, the shorter 3mm screw came from the middle hole.
BeatJunkie - 回复
来自 BeatJunkie 的话:
Thanks Beat Junkie, this was the situation with my Mac 2.13ghz Mid 2009 that I was putting back together. Thanks for the confirmation! (For the 6th step)
Cong Trieu - 回复
For me (A1181), there were two shorter screws and one longer. The longer went on the left (a shorter screw wouldn't catch). (Not the middle that is currently in the instruction. But that could be model difference.) The middle screw started to strip the head but using a slightly larger phillips allowed me to get it out.
In my late 2006 macbook the central screw was longer than the side screws..
Mine was A1181 model, Core 2 Duo 2.16 GHz. Of course I did not keep track of the screws and ended up with two shorter ones and one longer. Replaced them with the longer one to the right of the three. Got it done with a Wiha PH00 screwdriver. Had better hold than the bit from the precision screwdriver kit.
quentinlow - 回复
me too. Got it done with a iFixIt PH00 screwdriver.
Yeah, same for me, #00 worked; #0 suggested in the guide was too big. I didn’t even try #000. For 2.2GHz A1181. My screw config matched the guide, 3mm in middle, 4mm on the sides.
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
The steps do not tell you what length screw that is needed to be here. What I can tell you that is the screw needs to be 5mm or 6mm, NOT 7.5 or 8mm or 9mm.
Cong Trieu - 回复
Screwdriver PH0
For black 2.2GHz A1181, I used PH #000 as suggested by guide. My screws are both 6mm.
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
It's recommended to use a PH00 screwdriver instead of the PH000.
The PH000 is too small and you can damage the screwheads.
Yeah, I found PH #00 better too. (For black 2.2Ghz A1181.)
I used PH0 for this
Is there a way I can cut the bracket off? I completely stripped one of the screws?
I’ve done this often enough that I marked the screws to remove with red marker.
Peter Wood - 回复
Remove the following 4 screws from the back of the computer:
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
I cannot get the two outer screws out for the life of me- and afraid of stripping them. Already see I'm doing some damage. Help? What can I do?
Are you sure you have a proper screwdriver? From my experience you really need to use the correct size and not just something that seems to fit.
Olivia, you can screw back the longer screws that go on the inside. In the photo marked with orange. Then open and close the lid of the MacBook a few times. This will fit the 4 screws more properly in the steel inner-frame and they can come a little bit loose.
Close the lid again. Leave the inner screws untouched and begin with the outer screws (marked with red) with indeed a perfect matching screwdriver head (with a big and long grip for your hand). This worked for me perfectly without damage. Success!
Remove the two Phillips screws from the optical drive (right) side of the computer:
Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
The screw farthest from the optical drive would not come out, all other screws came out fine with my screw driver and the screw looks ok, any tips on how to get the screw out?
With some of the screws that can happen. I had it too. This did it for the MacBook I was repairing: 1. Open the MacBook. Then press firm but gentle on the upper case with your hand or fingers while trying to loosen the screw with your screwdriver. 2. I used a different screwdriver from the same size diameter but with a much larger hand-grip. Success!
在这个步骤中使用的工具:Plastic Cards$2.99
Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
As is reported above, there a 4 friction tabs that connect to the keyboard. If they do not stay in place and stick to the keyboard, the keyboard will not go back on. Just remove them and put them in the clips, with the solid clip wall to the outside of the unit, and put the keyboard back on. Do this before reconnecting the keyboard.
The front left had an annoying little metal strip between the outside of the case and the tab. It's very easily bent, so the tab was caught on it. I spent a good deal of time trying to push and pull various things (and even just yank the @$!^ thing off), but eventually I found that if you undo the two screws you are told not to in step 7, the battery connector can be pulled up and out, leaving enough horizontal room to pull out the metal strip (with a little bit of coercion). I left it out when I put everything back together.
Thanks for the tip. Saved me!
Joe -
Because this step requires some force, make sure to double check that you got all your screws out. I finally got my gumption up to apply the necessary force required to pull up the upper case, and after 5 minutes of pulling, I look and see that the reason it wasn't coming up because I missed one screw. Ugh.
Also, before you just shove your hands under the upper case, prying about, think twice: I cut my finger pretty bad on a sharp piece of metal.
When reassembling, take some care to align the tabs on the right hand side next to the optical drive. Rock and slide these tabs into position. Then work from right to left, as the rest of the case is quite easy to put back together.
I took my mac apart yesterday to clean out the trackpad properly and after getting some 'help' from my grandfather (he lost 2 screws and snapped off a bit of the uppercase but i didn't have the heart to ask him to leave it alone) i tried putting the uppercase back on. it fits perfectly but the middle section closest to the screen appears slightly raised and when i go to screw in the four screws on the exterior of the laptop i can't because the hole is not at all aligned (and two of those four screws are very long). anyone know why this might be? can it be fixed/is it a common problem?
If the upper case sticks above the optical drive, don't pull straight up, but up and to the left at the same time.
Wow, pulling both up and to the left made all the difference for me, to unstick the keyboard around the optical drive.
I think it is a mistake to separate the keyboard from the clips at the right side (above the optical drive) at all! Instead, after freeing the other three sides, just slide the keyboard slightly to the left, and leave the clips attached to the keyboard. For reassembly, just put the keyboard in its approximate place and slide it to the right to get those clips into position. Be sure the keyboard is really snug against the machine’s case. Then press the other three edges of the keyboard down.
jeh -
On the right side above the optical drive there are little plastic braces that latch the upper case to the main body. This is the reason why the upper case might stick here. If the above step is not working, also try to gently push the upper case sideways away from the optical drive after freeing all other sides. When reassembling make sure the braces are in their slots of the main body and not attached to the upper case. If you cannot fit the upper case evenly over the optical drive, that's probably why. In this case carefully remove them and slide them back into their slots before lowering the upper case.
this guide was awesome. this step was easy for the broken macbook i salvaged and noticed because i got a factory replacement keyboard quite recently on my macbook in use, the 4 clips above the optical drive were TIGHT - it took quite a bit of pulling up before it came loose!
While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
I tried to remove the blacktab from the logic board, however, the black tab tore apart. The logic board is okay but the keyboard connector is torn. It has some silver wires passing through a whit plastic housing. It is the first generation of MacBook Core Duo. Do you think it can be repaired?
After a sucessful install of the keyboard, the select (mouse buttun equivalent) was found to not operate consistently. I called support and they are shipping a new one out to me. THIS is why I buy from ifixit - sure I can get a part for less elsewhere - but I would not get the service I get with ifixit - THANKS guys!!!
jgreengold - 回复
Note - I agree, this was VERY easy - great pictures, perfect explanations...
jgreengold - 回复
来自 carlos 的话:
not sure if this is the place to ask but my mac. doesn't start properly now it turns on and the little light on the right side turns on but keyboard leds don't and display doesn't either any ideas please?
Did you ever find an answer for this question? My computer is doing the same thing. Thanks.
来自 E Chambliss 的话:
no i never did couldn't get help it blows to hear someone else had the same problem...im using a windows(yuk) but im getting a new mac next paycheck. if you figure it out let me know so i can fix my other one and maybe give it to my parents
来自 carlos 的话:
Hello, I'm following this procedure because my MacBook isn't turning on due to a failure in the MagSafe DC In board, it was not charging the battery and therefore no power going in. The case was broken duirng warranty and also the MagSafe power adapter was replaced. Now it is failing again. This is an old late 2006 MacBook. Does your Mac powers on, do you hear the chime sound? or you are stuck with a hardware failure?
来自 Francisco 的话:
my MacBook charges the battery and powers on i dont hear a chime and it turns on but never starts
来自 spi 的话:
When changing the topcase remember to change the sticker with the serial also! This might be important when further service or bigger repairs by apples service are needed. The serial also helps you with identifying your MacBook!
How do you do it? I can't get it out
Superb guide thank you guys
This takes some nerves if there is no tab, but be confident and just prise the connector straight up.
Clips removal: its hard with finger to pull. It's better and easy off with a pry tool (I used a flat twiser) to pry from the bottom gently for each clips. It was so smooth and easy.
After I clean everything nice… put the cable back and DO NOT TURN ON. What the !&&* happens!? Ideias my friends? :(
Sorry my bad english!
Getting the upper-case/keyboard off was a bit nerve-wracking. Just work away at it carefully, bit by bit.
A small torch (flashlight for our American friends) was handy to see what was happening underneath the upper-case. Otherwise too dark.
I used a photographic lens-cleaning blower (with the rubber squeeze bulb, just the blower, no brush) to get away the dust. Probably not as effective as canned air, but it worked well enough. I’d recommend avoiding touching anything with the tip of the blower. Keep it a few mm away.
After removing the keyboard I noticed that the side clips were not attached to the body but rather to the keyboard still. Easily removed but something to note.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
Note, if you’ve already installed an optical/SATA adapter, and you’re doing this just to replace the SATA drive, then you might be able to skip almost all of the following steps. It seems that for the sort of adapter described in this guide (with the drive secured by a plastic positioner), you should be able to leave pretty much everything in place, and swap out the SATA drive (though you might need to move the Bluetooth antenna holder out of the way).
Unfortunately for me, mine is a different kind of adapter, with the drive secured by screws from the underside, so I still had to go through almost all the steps to get the adapter out. I can’t even remember where I got the adapter. I think it was probably from iFixit, but it might have been a different, earlier version.
Backstory is that I put an SSD in the adapter a few years back to replace a dead optical drive. And it worked with the extra drive, but it seemed to function slowly, at optical-drive rather than SSD speed. Recently, the machine stopped detecting the extra hard-drive. I don’t know why. My guess is that in an upgrade something changed in how the kernel detects devices, and it got confused by an SSD being where it expected an optical drive. (I’m running Debian GNU/Linux, it being the only way I can run up-to-date software on a machine no longer supported by Apple, and I’m a Free Software enthusiast anyway.) Your mileage may vary… Because the SATA drive wasn’t being detected, and I needed access to the data on it, I had no choice for the time being but to take out the SSD and go back to a single-drive machine. The main drive is SSD, and I’ve upgrade to the max 6GB RAM, so it’s still a pretty useful machine.
I’m planning to put the adapter back in, just in case the void would be bad for cooling air-flow.
Remove the two Phillips screws from the side of the optical drive.
Two 3.25 mm Phillips #000 (head: 4 mm. dia. x .3 mm thick)
!! I can't remove the left screw, and ended up "screwing" it.. it's a round hole now. What should I do?
wkurosawa: The optical drive will stay put properly if the screw on the left isn't installed.
Disconnect the newly revealed display data cable's plug from the logic board by pulling it upward using its black pull-tab.
The display cable was difficult to disconnect for me. I had to pull firmly and use the spudger at the same time to finally pop it off.
I pulled firmly on the tab, while rocking back and forth slightly.
Disconnect the newly-revealed hard drive cable's plug from the logic board by pulling it upward using its black tab.
When reconnecting the Hard Drive Cable to the logic board (Step 17) I ran the HD cable on top of the microphone wire, and the other wire that runs parallel to it, when I should have run the HD cable underneath those two wires. This resulted in the hard drive not being connected on startup, and a lengthy troubleshooting session to figure this out. So save some time and install this underneath the two wires, just like you found it when taking it apart!
Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
During reassembly, be sure to route the cables beneath the tape before reattaching it.
I was gently pulling up the tape with a spudger, but the tape snapped clean in half right at the edge of the optical drive. I'm really pretty surprised because I see no reason why it would have done that.
How crucial is it to have tape here (foil or otherwise)?
Peter Wood - 回复
Remove the 2 mm Phillips #00 screw securing the rear corner of the optical drive.
The silver-jacketed Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to remove the screw holding the ground shield lugs for the two nearby cables before you can move the Bluetooth cable aside sufficiently. This screw is 7mm in earlier models, and may be 4.2mm in Santa Rosa/Penryn and 2009 models.
STEP 20 - IMPORTANT= This screw secures a mounting bracket on the optical drive. This bracket's eyelets are slotted. The right side of the bracket has a tab inserted in the bottom case. After removing the screw, use the spudger to slide the bracket to the left. This disengages the tab from the right side of the case, thus allowing the optical drive to be lifted out in step 23.
As an addition to xtian's note, the bracket that you need to slide right (and a spudger is very useful here) it may be because the rear right (as in the picture) of the optical drive needs to be GENTLY pushed down as the bracket end needs to slot into a hole on the right hand side of the case.
Ernie K -
After removing the screw gently push the metal tong (which the screw was holding) towards the fan. This will unlock the drive mount.
I found it helpful to remove the screw sitting to the lower left of the speaker.
There is only one screw holding the optical drive down, the one circled in red. the one in orange is for the ground loop for the microphone and right speaker cable. Also, a spudger makes quick work of moving the cables out of the way to get to the screw for easy removal/replacement.
Leo LeBron - 回复
As I tried to refit the optical drive, the plastic mount for the brass threaded socket that receives the screw crumbled like an old tooth. Only thing for it was to ditch the plastic and superglue the brass socket into place on the case - seems to have worked. (People who design parts/fixings that involve strong materials held in place by weaker ones should be imprisoned). I also had to remove the sliding bracket on the drive and cut 2/3mm off the right hand end to get the screw hole to align with the brass socket, also seems not to have caused any harm. Never thought I would find myself lashing out with the superglue and wielding a hacksaw inside a laptop...empowered!
Lift the side of the optical drive closest to you, then slide the drive towards you, and up and out of the computer.
First, slide its side nearest to the rear of the Macbook under the edge of the rear frame to the left of the hinge, while also sliding the optical drive's mounting tab at its upper left corner under the cables at this location.
Lower the drive partially into the lower housing. Keep the hard drive cable away from the optical drive bay.
Before dropping the drive fully in place, use a spudger to push forward (towards the front of the drive) on the screw hole in the drive's mounting tab.
Push forward the slider, which runs along the far side of the drive, to insert the end of this slider into a small channel in the lower case's frame. This helps hold the drive in place.
On the the optical drive there is a sliding-bar (secured by two screws, which fixes the drive in the right edge of the Alu-frame) that has to be shifted to the left when taking the drive off. Especially, before putting the optical drive back to the computer, make sure that the the sliding bar is in its leftward position in order not to block the insertion of the drive. Then shift the bar gently to the right thereby fixing the drive's position.
Thanks! Even so, I had to get the drive aligned just right, so that the sliding bar could mate with the matching slot in the case.
For original Macbook Core Duo and Core 2 Duo models, remove these 3 screws:
Two 3 mm Phillips near the right speaker.
One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
For Santa Rosa/Penryn and 2009 models, which don't have a c-channel:
Remove only the single 3 mm Phillips screw from the right speaker, and skip step 26.
Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the plug back and out of its socket.
Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
I find it very strange that it’s omitted, but to deroute the microphone cable, you will have to unscrew the cable right next to (above) it. At least, I had to. It’s not hard, but you can’t deroute the microphone cable without derouting the other cable.
Make sure to remember that this screw is removed when reassembling!
If you didn't remove the ground lug retaining screw in step 20 above, remove it now. It's a 7mm (may be 4mm or 3mm in Santa Rosa/Penryn and 2009 models) Phillips screw securing the ground lugs on the right speaker cable and microphone cable to the metal frame.
Put close attention to how the cables are laid out to get the same staking order, when reassembling I did not care about the order and as a result they were not as "Flat" as before and made the DVD drive insertion a bit more hard as it did not sit as deep as it should, so I had to re arrange the cables and once they were right the DVD drive sat perfectly. I would suggest taking a photo before re-routing them.
For the second time that I changed an inverter I skipped to disconnect the microphone cable (steps 27 to 30) because it's really hard to wiggle the connector out of its socket and it looks very fragile.
By doing this you can not move the display assembly far from the case BUT it's not a problem for the next steps (front bezel and clutch cover).
I won time and did not have to replace display and microphone cables what is not easy because of the lack of place and if the SuperDrive is compressed it can block CDs.
Not sure if that will help...
Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
Remove the single 3 mm Phillips screw securing the ground lug in the display data cable located just above the Bluetooth board. This screw may also be securing a ground lug in the speaker cable.
The ground screw also holds down a ground loop that is part of the speaker cable. The two loops may be stuck together so you need to carefully separate them.
kyoungdale - 回复
Disconnect the antenna cables from the Airport card:
If you have an original MacBook Core Duo or Core 2 Duo model, see the first picture, which shows that there are three antenna cables.
If you have a MacBook Core 2 Duo Santa Rosa/Penryn or 2009 model, there are only two antenna cables, and the plug/socket for the black inverter cable is in a different location. There may be a square foam piece over the plug/socket for the inverter board connector.
Disconnect the inverter cable from its socket by inserting a spudger between the right or left ends of the plug and the socket, and prying gently vertically. Do NOT pry up on the socket--you must pull up on the plug alone, vertically out of the socket. Do not pull in the direction of the cable wires or you will tear the socket off the logic board.
For the MacBook Core 2 Duo Santa Rosa/Penryn: the inverter cable is a bit tricky. I was fooled into thinking that there were pins which went INTO the inverter cable. Because of this, I was afraid of lifting up on the cable (off the board), but this is what you actually must do to separate them.
For clarification, here's a pic (low-res, sorry) of the inverter cable disconnected from it's on-board plug: http://lh4.ggpht.com/_l0f6yKkaxDU/S0FOHS...
Can I get a replacement connecter that the inverter cable connects to and solder it on? I broke mine taking to of how it says in the guide
i also broke mine off the motherboard on accident. it appears to be a fairly clean break. is there anyone who has had luck soldering them back on?
michael -
About disconnecting the inverter cable. I had more luck wedging the pointed end of spludger between the PCB near the cables and the shoulder of the connector nearest the display. I then pushed the pointed end of the spludger away from the display and the connector popped up off the socket. when trying to use the spludger on the sides of the socket, i deformed the plastic edges of the socket.
This worked well for me too.
The inverter cable was fine if a little fiddly, but I can't get the antenna cables back on at all - anyone got any ideas? Even with bright lights and magnifiers I can't see why they won't go back in. (And I don't know why ifixit thinks I'm called facebook -- Sam)
... and of course as soon as I ask for help I find the answer. Don't try to push the plug vertically into the socket on the Airport board, start it at an angle with the cable running up and away from you towards the screen, then rock it back horizontal and it just clicks into place. -- Sam
facebook -
For original Macbook Core Duo and Core 2 Duo models, see first picture and remove the following 2 screws from the right hinge mount:
One 6 mm Phillips on the left side of the hinge mount.
One 10 mm Phillips on the right side of the hinge mount.
For Santa Rosa/Penryn and 2009 models, see second picture and remove the following 3 screws from the right hinge mount:
One 3 mm smalller diameter Phillips on the far left.
One 5.2 mm larger diameter, 4.2 mm head Phillips in the middle.
One 10 mm larger diameter, 4.2mm head Phillips from the far right.
Before removing the right hinge mount, take care to see how its pieces fit together, including the small white plastic piece. Knowing how the mount pieces fit together will help with reassembly. Lift the right hinge mount with the small white plastic piece out of the computer.
Hold the display with one hand while removing the following 3 screws from the left hinge mount:
One 7.2 mm smaller diameter Phillips from the right side.
One 5.2 mm larger diameter Phillips from the middle.
One larger diameter 10 mm Phillips from the left side.
Lift the left hinge mount with white plastic piece out of the computer.
Check that the cables coming out of the right end of the left hinge are not trapped under other cables.
I tried this last night and the screen fell backward, cracking the components of the hinge. Be careful and support the screen here once you unscrew the hinges!
What is that plastic hinge thingie called in step 34. The piece broke and I'd like to replace that.
Can anyone else confirm what I’ve written below?…
In my macbook, which is the regular (not Santa Rosa/Penryn) model, the longest 10mm screw is the same, but the middle screw and the right screw are both approximately 5mm. However, the middle screw is fatter/wider and the right screw is thinner.
Also, when reassembling, make sure all three screws are easily screwed in before tightening each one. The hinge mount that you’re fastening down will wiggle a bit before being fully tightened down, possibly causing the screw holes to not line up!
Grasp the display assembly on either side and lift it up and out of the computer, taking care that the cables attached to the display don't snag on parts in the lower case.
For those wishing to go further into the LCD, the steps are identical to the MB CD, see this repair guide for more:
Use a thin plastic card to release the tabs and their clips holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
When you go to replace the bezel, look at the back side and disconnect any of the little snap-on tabs that may not have stayed in the metal bracket around the LCD. On a white MacBook they were grey, about 4mm x 8mm. They work best if you put them into the metal frame separate from the bezel and then snap the bezel into them.
The best way to remove them seemed to be by placing my thumb over one edge (so they didn’t fly off) and prying with a thin, flat screwdriver flat against the bezel tab.
Hello I've seen a video on Youtube where the guy skipped all the previous steps and got to the inverter without taking the screen off. Seems like it saves a lot of time and potential problems, since I have never done anything like this. Does anyone recommend doing it? I see it's more accessible to just try to get to the inverter without taking the screen off first.
Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
After freeing all holding tabs, lift the front display bezel away from the display assembly.
A note for anyone panicking because they can't get their front bezel back on:
It is common for the grey clips holding the bezel to the display to come up along with the bezel. If you have ANY grey clips attached to the back of your bezel, in order to replace the bezel you need to first remove the clips from the bezel and reinsert them into the holes in the display panel manually first! Once all of these clips are back in place, the bezel can be reattached.
These clips are very fragile and if you are having this problem odds are you have already severely bent some of them. Check the tiny plastic clasps and if they are squashed down, gently pry them back up with your fingernail. Again these grey clips are very fragile, so use care in reattaching them.
This was a very helpful tip. I made the mistake at first when reading your note, thinking that the gray clips were supposed to be on the bezel, not the display, but quickly corrected that.
For anyone confused, the bezel is the thin plastic part surrounded the display, and the display of course houses the LCD.
Another note:
The easiest way to remove the clips from the bezel is from the side and pry up. To reattach them to the display, put one end of the clip in first, and then use tweezers to poke in the other end of the clip.
来自 WillyDavidK 的话:
Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel. A 0.8mm flat screwdriver may be useful for this step. You may find that it's easier to remove some of these clips by prying up on their long sides.
I found that an easy way to remove the clips from the bezel is to use a plastic knife (knife as in the utensil). Sliding the knife under one of the clip's long sides and prying upwards worked well for me. Thanks MC25 and WillyDavidK for the tips, they worked great!
The plastic clips deform easily, making it difficult to reuse them. The tabs on the back of the bezel that fit into the clips also break off easily.
If any of the tabs or clips are omitted, the bezel will not lie flush nor will it hold the cables that run beneath it in place.
Wear gloves while wrangling with the white bezel—like the white topcase, the matte-finish plastic is very porous and quickly gets grubby.
Remove the three 4.2 mm Phillips screws securing the clutch cover.
In this picture you can see that it is a Nikon camera that was used for this guide. :)
While holding the display down with one hand, use your other hand to lift the left end of the clutch cover off the clutch hinge and guide the inverter cable and AirPort cables through the gap in the clutch cover. If the cables snag on the two hooked tabs on the inside end of the clutch cover, free them carefully.
There are little clips at each end of the clutch cover, and I found it helpful first to lift the clutch cover off the metal rod first, and after that squeeze the cables at each end between the clips, so you can lift the cover off.
Lift up the right end of the clutch cover while guiding the display data and iSight cables through the gap and the two hooked tabs at the right end of the clutch cover. If the cables snag on the two hooked tabs, free them carefully.
Lift the clutch cover off of the display assembly.
Pay attention here. I missed the part about pinching the cable and that's exactly what I did. It helps to pull the video and mic cables tight to fit the clutch cover on. I also had to make sure the pink/white cables were up and out of the way. When I did it correctly, it slid in pretty easily. It would help to really look at how things are arranged when you are taking it apart, too. There's some tabs that interconnect with the plastic sliding things you removed in steps 46-47.
maccentric - 回复
Lift the inverter slightly out of the display.
Disconnect the inverter cable from the left side of the inverter board.
Set the inverter board back down into its recess molded into the rear display bezel.
249等其他人完成本指南。
32条评论
i did it! Was quite scary opening and putting those parts together. But screen good as new now! :D :D :D
This fix took me 5 hours to do from start to finish. Most difficult part was removing the keyboard assm on the front left corner. It gets caught under the metal support brace inside the case where the two outside screws are. Very tedious job but worth it because it fixed the backlight problem on my Penyrn Macbook.
Thanx very much for this very usefull guide! I replaced the inverter cable of my macbook and now the screen stays on as it should be! Very nice to have such a close look at the inside of the macbook
This Guide worked and was expertly written!!! Thanks for the help my macbook screen now works again!!!!
Worked excellent! Thnx ifixit and dozuki for clear guiding!
Be carefull when putting back the keyboard (step 11: slide 4 grey bits into slots) and check before closing if connector to logic board is still in!
This guide is very clear and nicely covers potential mishaps. HOWEVER, after I reassembled my macbook there was
no response to pushing the power button!
Any suggestions?
ted ballou - 回复
HAPPY! took off the keyboard and, whoa, the keyboard/trackpad connector was loose: stuck it on and it powered up just fine, with perfect backlight behavior!
ted ballou - 回复
Awesome! Thanks iFixit! Worked perfectly. Only cost me a few bucks!
I followed the guide step by step and had some pieces of paper with step-numbers on it to arrange the screws. Messing around with my Mac always makes me nervous but this guide pulled me through.
My MacBook went black whenever I moved the lid up or down slightly. Considering the rather poor viewing angle of the display, that happened quite often. I just took it apart; pressed everything firmly while reassembling the machine and now I can move the lid without the screen going black. Excellent !
Thanks a million for the walkthrough !
This guide worked really well for me, apart from the expected slight glitches which are par for the course (see my comments on Step 20). A useful tip is to use an ice cube tray for the screws/parts - as you take them out, put them in a cube well and mark it with the corresponding Step number. Makes it easy as you go in reverse order to reassemble.
Although a lot of steps, and painfully gruesome ... I was able to replace the Inverter Cable, since the one inside was giving me a lot of flickering when the backlight went off.
Thanks.
Cheers every one
Andrew Bookholt thx for the tutorial its really great. I've managed to follow your guide and now I have access to the inverter cable. I think the problem is on the inverter cable not on the inverter itself. Every time I unplug and then plug the inverter cable from and to the inverter the screen flashes and then goes off again. Does this mean the problem is on the cable? I think I'm pretty close to fix my mac but I would like to be sure which part toCan someone help me out please? Thx in advance to ll of you
Great guide!!! My inverter cable is repaired!!!
For about 3 years I had been dealing with my screen backlight shuting off. I would then dim the screen up and down until I could get it to stay. Sometimes it would work the first time other times I would be doing it for 10 minutes and other times I would give up for a few hours and come back and the screen would be on again. It would also do this sometimes when I opened the laptop at a certain angle or bumped the computer.
Well after these years very annoying behavior, my screen wont turn back on. I can see my desktop when I shine a light on the screen and hear the fan running so I know the computer works fine.
I've tried unpluging the inverter board to see if it was a loose connection, but that didn't work. I tried wiggling it around until the screen turned on and nothing.... Please help!
Is this a problem with my inverter or the inverter cable? Or the backlight cable?
What parts should I buy?
Yep, did it myself, saved money, got to sit back and enjoy the satisfaction of a job well done.
Thanks Andy, BIG help my friend!!!
rickywayne - 回复
Worked great; display is no longer intermittent. Penryn model, all screws were #0. Took a few photos to help on reassembly, and made a couple of missteps: plugged in optical cable before hard drive cable, and had to backtrack one step; and put the 3 battery compartment screws in the wrong holes; had to take them out and put them in the right holes so the shield screws had empty holes. Took me 6 or 8 hours over three days. Thanks!
rob3p14159 - 回复
Wow, this actually worked! I paid c.£200 for a similar repair a few years ago and wasn't willing to spend the same again on my ancient macbook, so figured I'd give this a try.
Opening up the inside was pretty scary and I fully expected to do more damage than good. In fact, my first attempt produced a blue screen with a question mark icon, so I repeated steps 1-18 to check for a loose connection/trapped cable and, much to my amazement, that fixed the problem! Saved me a fortune!
For those in the UK, the "iFixit iOpener Kit to open Apple glued devices" from Amazon contains all the kit you need apart from the inverter cable/compressed air.
Great guide, well written. Sadly in this case a new cable didn't fix the backlight problem, must be screen, inverter board or something else.
Right, now show me the way back ;) just kidding,
thanks to this really great tutorial I've just fixed my daughter's beloved whitebook
hope I can assemble it back, now ;)
for those, who didn't find the solution in cable or inverter replacement:
the very common problem here is a zero ohm resistor, which serves as fuse here
this tiny beast just loves to be burnt, and residues nearby the inverter connector slot
you may find pictures here:
Voltages of pins on logic board where inverter cable hooks up..
and appropriate video here:
https://www.youtube.com/watch?v=YQxCe0iZ...
cheers
long live, white apples!
Guide worked great. Thought it was odd that the inverter cable had to be twisted in order to fit it and screw it into the display. The cable I replaced was also twisted which makes me wonder if that was not the problem.
You went through everything but FAILED to show how to take out the Inverter cable from the mother board. Do we pull up or down or just out.
Performed the entire thing without issue, I thought. My macbook will not boot up. I do get the Apple logo, followed by a spinning icon, then a blue screen, then it shuts off. Any ideas of what to check? I reopened it and checked all the connectors to be sure they were snug.
Went to turn the computer on but nothing happens. So I disassembled again to see if I missed something. This time, before I reassembled eveything, I basically connected all the cables, inserted the hard drive, connected the keyboard and attached the powercord. Turned the power in and it worked. But the keyboard didn't work other than the power button. So I connected a usb mouse. I have no Bluetooth connection. Went ahead and powered off and finished putting it back together again. But the power button and nothing . What happened???
would this work on a 2016 mac?
Thank you ifixit! Another great guide. Just followed the steps and repaired my inverted cable. It took me about 2 hours! Now my MacBook works great again!!!
Best guides ever. Thank you. I just don't know which cable is for backlight. I thought it's the LCD DATA CABLE and changed the whole LCD + Data Cable but not the inverter and it's cable. I guess that might be the issue!
I used this guide plus the Thermal Paste guide to resolve my MacBook RRS (Random Restart Syndrome) issue. My MacBook would randomly restart after the fan kicked into high speed. When I removed the heatsink I discovered an an irregular patch completely free of thermal compound of about 15-20% of the area on one of the processors. I removed and re-applied the thermal paste. I ran a memory test utility overnight that previously caused a restart after a couple of hours, and the probelm seems to be solved. TIme will tell.
ServiceDocs - 回复
This guide was seriously helpful, so thanks for putting this together. I found a thick ribbon of dust/muck whatever between the fan outlet and the exhaust port that was almost as dense as felt. My fan must have been fighting like crazy trying to pass air through that blockage, which explains the high temps and excessive fan noise. Wish I'd done this sooner...
Thanks again!
skraggle - 回复
Just R&R'ed the fan in my black MacBook Core 2 Duo tonight. Took me 30 minutes tops and I was taking my time. These instructions are SPOT ON! Great job ifixit.com! Two thumbs up!
Follow the instructions exactly as you see and have a piece of paper taped to the table next to you that you can outline all the screws you took out so you know where they go back in. I expected this to be a LOT harder, but it was one of the simplest repairs I've ever done to ANY computer!
mikeutter - 回复
Piece of cake--or should I say gum. If you don't have a magnetized screwdriver, load up a stick of gum and chomp on it until it's needed then use a bit to retain screw on the driver. And if you should tear the black tape, or if the silver tape won't stick any more, just bubblegum it together. The instructions were clear and correct, which made for a very simple repair.
Mike Woodruff - 回复
My battery does not pop out when after step 1. Any idea why, and how do fix it?
Calvin - 回复
Will not drop out even if you turn it upside down?
skraggle - 回复
Somehow, now my isight camera doesn't work and the light is always on. Cannot figure out what I did wrong.
josefsalyer - 回复
Somehow the plastic disc with the slot for a coin got dislodged from the case, and I can't seem to get it open now. Any tips/links on how to open this without the aid of the plastic disc?
Peter Wood - 回复
i broke my disc off as well. I used two toothpicks to rotate the thing. hi tech.
howard bederman -
Outstanding guide - thank you!
owen bullock - 回复
My computer will not charge when plugged in. It will stay on as ling as the plug is in the wall however if the power source gets disconnected it will shut down immediately. I removed the battery and put it back in that did not help. It worked and charged fine 2 days ago. I have a backpack with a laptop storage area. I went to hang the backpack up and it fell and ever since the battery is not functioning. Is there some fix I can try or is my only solution to replace it? I would have thought that dropping it would affect more than the battery?
Beth Tomasek - 回复
Better leave the back pack where it cannot fall. Hindsight is so much better than foresight . I learned the hard way too!
Loy Lum - 回复
Many of the tiny screws in this project were quite sticky. I found some blue Loctite residue that must have been when the Apple repair shop worked on the laptop years ago. I have found that it is important to hold the correct driver firmly down in the screw and then just tweak the driver in short bursts to loosen it before unscrewing it with a smooth turn.
Patrick Langvardt - 回复
Be really careful while doing this to not use too much force while doing this step, because the plastic disc can break off and it can be a cosmetic issue along with functionality issue. This happened to me first hand so please take my word for it…
[deleted] - 回复
Probably worth mentioning at this stage that the caddy you propose to use should not have lugs on the front corners, like those used in unibody 1278 and onwards.
harwood - 回复
Hehe, still my mac os running! After, already bit more than 10 years of use!
I put new heat paste now for the second time. Maybe this helped for staying young so long.
Thanx for all the repair guides!!!
Fabien - 回复
