跳转到主内容
MacBook Air 13" Retina Display 2020 Smaller Keys Replacement
你所需要的
  1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement, Smaller Keys: 步骤 1 中的图像 1,1
    • Clean the keyboard.
  2. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 2 中的图像 1,2 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 2 中的图像 2,2
    • Gather all necessary pieces that may have come off with the key.
    • The key itself.
    • The hinge piece.
    • Orient the hinge piece in the proper position.
  3. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 3 中的图像 1,3 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 3 中的图像 2,3 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 3 中的图像 3,3
    • Install onto single mount first.
    • Then press into the double mount.
    • Make sure the hinge is in place properly, or the key will not stay on.
  4. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 4 中的图像 1,1
    • This piece, the rubber cap, doesn't come off often. But if it does, you can reinstall it by pressing down on the middle.
  5. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 5 中的图像 1,2 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 5 中的图像 2,2
    • Orient the key in the proper position.
  6. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 步骤 6 中的图像 1,1
    • Press the key down into place.
结论
To disassemble your device, follow these instructions in reverse order.
一条评论
Is this strictly for the early 2020 MacBook Air, or will this same technique work for the late 2020 MacBook Air?
iannai29 - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 72
过去 30 天: 324
总计 8,017
