简介
Use this guide to replace the trackpad in a 2019 MacBook Air.
你所需要的
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
Remove the trackpad connector bracket.
Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
Slide the sound board cable out of the ZIF connector.
Use a T5 Torx driver to remove the following screws:
One 5.5 mm screw
Three 2.6 mm screws
Two 1.9 mm screws
Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the upper case.
Use the flat end of a spudger to lift the small locking flap on the trackpad ZIF connector.
Slide the trackpad cable straight out of its connector.
Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the battery.
Use a T5 Torx driver to remove the following screws securing the trackpad:
One 3.2 mm screw
Eight 3.1 mm screws
Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
Slide the trackpad cable straight out of the ZIF connector.
3等其他人完成本指南。
