本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the I/O board.
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
45等其他人完成本指南。
8条评论
How can I tell if its my I/O board that is damaged? I cannot hear sound from Aux port or from the speakers on my macbook. Laptop still charges fine though.
