本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a dead or noisy fan.
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
46等其他人完成本指南。
6条评论
I also broke the retaining flap. For now, I just reinserted the ribbon. Is the function of the retaining flap just to hold the ribbon in place? Since then my computer has been entering sleep mode/shutting down during use, but I also did a battery replacement recently.
Good stuff! Thanks.
VFRDon
Got it flawlessly! Thanks!
