跳转到主内容
  1. 这个步骤还没有翻译 帮忙翻译一下
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
终点
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 7
过去的30天: 14
总计 9,876
