跳转到主内容
MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement
你所需要的
  1. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    购买
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 1,2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: 步骤 5 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 1,2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 2,2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
结论
27等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
428,116 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
4条评论
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
James Walsh - 回复
Will a 2012 MBA wifi antenna work with a 2014 wifi card?
Archie - 回复
I'm getting a "Wifi: No hardware installed" with an X over the wifi icon in the Menu.
Even after I swapped the original Airport card with a second one. Neither one works. The original worked up until a short time ago. I hadn't used the Air for a few months, but when I started it up the Airport wasn't recognized.
Also, should mention that Bluetooth works fine.
Could it be the Airport cables?
Specs: 13" Air (2014) running Mojave 10.14.1
Simple Simon - 回复
I use a Netgear router with a Macbook Air 13, and the internet is very slow with it, and the connection is always disconnected and back on.
Bassem Abaza - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 69
总计 19,299
