跳转到主内容
MacBook Air 13” Retina Display Late 2018 Logic Board Replacement
你所需要的
  1. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Remove the screws securing the lower case: 步骤 1 中的图像 1,1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Remove the lower case: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Disconnect the battery: 步骤 3 中的图像 1,1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 4 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Disconnect the logic board: 步骤 5 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Disconnect the logic board: 步骤 5 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  6. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 6 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  7. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 7 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 7 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 7 中的图像 3,3
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  8. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 8 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 8 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  9. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 9 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 9 中的图像 2,2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  10. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 10 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 10 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  11. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 11 中的图像 1,1
    • Peel back the black tape covering the fan cable connector.
  12. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 12 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 12 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 12 中的图像 3,3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  13. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 13 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 13 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  14. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 14 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 14 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 14 中的图像 3,3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  15. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 15 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 15 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  16. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 16 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Logic Board Replacement: 步骤 16 中的图像 2,2
    • Use the flat end of a spudger to pry up the display cable connector.
  17. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Unscrew the logic board: 步骤 17 中的图像 1,1
    • Use a T5 Torx driver to remove the following screws:
    • One 5.5 mm screw
    • Three 2.6 mm screws
    • Two 1.9 mm screws
  18. MacBook Air 13” Retina Display Late 2018 Logic Board Replacement, Remove the logic board: 步骤 18 中的图像 1,1
    • Remove the logic board.
结论
12等其他人完成本指南。
Adam O'Camb
于04/11/15注册
196,299 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 86
过去 30 天: 287
总计 11,934
