跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2013 Fan Replacement
你所需要的
  1. MacBook Air 11" Mid 2013 Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    添加评论
  2. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    添加评论
  3. MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
    添加评论
  4. MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: 步骤 4 中的图像 1,2 MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
    询问修复机器人
    添加评论
  5. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 5 中的图像 1,1
    • Lift and remove the I/O board cable.
    询问修复机器人
    添加评论
  6. MacBook Air 11" Mid 2013 Fan Replacement, Fan: 步骤 6 中的图像 1,2 MacBook Air 11" Mid 2013 Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
    添加评论
  7. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 7 中的图像 1,2 MacBook Air 11" Mid 2013 Fan Replacement: 步骤 7 中的图像 2,2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
    添加评论
  8. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 8 中的图像 1,2 MacBook Air 11" Mid 2013 Fan Replacement: 步骤 8 中的图像 2,2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    添加评论
  9. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
    询问修复机器人
    添加评论
  10. MacBook Air 11" Mid 2013 Fan Replacement: 步骤 10 中的图像 1,3 MacBook Air 11" Mid 2013 Fan Replacement: 步骤 10 中的图像 2,3 MacBook Air 11" Mid 2013 Fan Replacement: 步骤 10 中的图像 3,3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,418 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了25,930篇指南
1指南评论
I have error PPF004.
Liviolog4 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 61
总计 7,323
