跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2013 Display Assembly Replacement
你所需要的
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 2,2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board Cable: 步骤 4 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board Cable: 步骤 4 中的图像 2,2
      • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Lift and remove the I/O board cable.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Fan: 步骤 6 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement, Fan: 步骤 6 中的图像 2,2
      • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
      • We recommend you gently "walk" the connector out of its socket.
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 7 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 7 中的图像 2,2
      • Peel the iSight camera cable up off the adhesive securing it to the fan.
      添加评论
    3. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 8 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 8 中的图像 2,2
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      添加评论
    4. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.5 mm T5 Torx screws
      • One 4.6 mm T5 Torx screw
      • In some models this is a 3.6 mm T5 Torx screw.
      询问修复机器人
      添加评论
    5. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 10 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 10 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 10 中的图像 3,3
      • Lift, but do not remove the fan out of its recess in the upper case.
      • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: 步骤 11 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: 步骤 11 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: 步骤 11 中的图像 3,3
      • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 12 中的图像 1,1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 13 中的图像 1,1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      询问修复机器人
      添加评论
    4. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 14 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 14 中的图像 2,2
      • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
      添加评论
    5. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 15 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 15 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 15 中的图像 3,3
      • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
      添加评论
    6. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 16 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 16 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 16 中的图像 3,3
      • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
      • While holding the lock away from the socket, gently pull the display data cable out of its socket.
      • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
      询问修复机器人
      添加评论
    7. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 17 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 17 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 17 中的图像 3,3
      • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
      • De-route the cable from its notch in the logic board.
      询问修复机器人
      添加评论
    8. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 18 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 18 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 18 中的图像 3,3
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
      询问修复机器人
      添加评论
    9. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 19 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 19 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 19 中的图像 3,3
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Pull the keyboard backlight ribbon cable out of its socket.
      询问修复机器人
      添加评论
    10. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 20 中的图像 1,1
      • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
      询问修复机器人
      添加评论
    11. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 21 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 21 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 21 中的图像 3,3
      • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
      • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
      询问修复机器人
      添加评论
    12. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 22 中的图像 1,1
      • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
      • In some models these are 3.1 mm T5 Torx screws.
      询问修复机器人
      添加评论
    13. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 23 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 23 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 23 中的图像 3,3
      • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
      • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: 步骤 24 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: 步骤 24 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: 步骤 24 中的图像 3,3
      • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
      • Remove the gasket from the corner nearest display cable connector.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 25 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 25 中的图像 2,2
      在这个步骤中使用的工具:
      • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 26 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 26 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 26 中的图像 3,3
      • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
      询问修复机器人
      添加评论
    4. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 27 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 27 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 27 中的图像 3,3
      • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
      添加评论
    5. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 28 中的图像 1,1
      • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
      询问修复机器人
      添加评论
    6. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 29 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 29 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 29 中的图像 3,3
      • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 1,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 2,3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 3,3
      • Peel up the six cable loops securing the antenna cables to the upper case.
      • In some models there are seven cable loops.
      • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
      • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
      • Repeat this for each retaining loop until the antenna cables are free from the upper case.
      添加评论
    2. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 31 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 31 中的图像 2,2
      • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 32 中的图像 1,1
      • Open the display until it is perpendicular to the upper case and place it on a table as shown.
      • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
      询问修复机器人
      添加评论
    4. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 33 中的图像 1,1
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
      询问修复机器人
      添加评论
    5. MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 34 中的图像 1,2 MacBook Air 11" Mid 2013 Display Assembly Replacement: 步骤 34 中的图像 2,2
      • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
      • Once the two display hinges have cleared the upper case, remove the display.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
30等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,842 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了49,862篇指南
3指南评论
Great tutorial. Easy to follow. Don't be afraid to do it.
Corey Campbell - 回复 分享
I wish the tutorial showed the procedure for tearing down the LCD and backlight panel... So not fun.
Sam Anticks - 回复 分享
is this Display of macbook air mid 2013 can fit into macbook air mid 2012?
juantajoe - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 68
总计 25,995
