简介
Prereq to disconnect the battery.
你所需要的
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
即将完成!
结论
When reassembling the connector wire needs to be bent to fit.
GERARD SZAREK - 回复
