简介
Use this guide to replace your MacBook Air's upper case. The upper case includes the keyboard and trackpad.
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
My macbook air's configuration (Mid-2011 core i5) has a different battery connector. It slides into a receptacle on the logic board. If your battery connector does not look like the one pictured, use the pointy end of a spudger to depress the small indentation in the middle of the battery connector cable terminal, and pull aft to release the clasp mechanism.
Maybe your battery connector doesn't match the picture because these instructions are for the mid-2012 model and yours is mid-2011.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
Pull the drive straight out of its socket and remove it from the logic board.
When you've completed all these steps to replace your SSD, don't despair if the MacBook Air shows a flashing folder with a question mark when you first power up the MacBook Air.
- Power off the machine, then keep the option key (= Alt key) pressed down, power on the machine again, and keep the option key pressed down until a prompt appears.
- If you've set a firmware password, then type it in at the prompt
- You should now be prompted for a hard drive to boot from. Select "EFI Boot"
- The MacBook Air should now boot to a window showing "OS X Utilities"
- Click on the at the top left, then select "Startup Disk..."
- Select your SDD/Hard drive, and restart.
When replacing the SSD, be careful about the connector orientation. Replacement boards look almost the same if they are upside-down. Note that the connector is not reversible - there is a notch that will only line up if the board is right-side up. If it doesn't seem to line up, flip the board over.
can i ask some links for some ssd’s that are compatible with that macbook model ?
Hi I completed steps above, but the MacBook Air 2012 doesn’t seem to read the drive, on reboot I get a flashing folder, and upon clicking Control R on reboot it goes to internet recovery mode and then can’t find the drive on disk utility. Any help would be much appreciated! Thanks, Devin
if you’re using an M2 adaptor, be mindful to check the compatibility with the other end. In my specific case my adaptor was only compatible with M2 Sata and not with M2 NVMe.
This was a confusing upgrade. Sintech M.2 NGFF SSD fo 2010-2011 MacBook Air was used, yet it’s got a graphic in the sales content that claims it works with ‘M’ key only (NVMe, AHCI), so NOT SATA. Yet in the answered questions on Amazon the sales tech claims you MUST use SATA drive. I bought 2 NVMe SSD’s and found that the first USB adapter board was unstable with both. So, bought another adapter board that supported SATA and NVMe (RIITOP M.2 SSD to USB 3.1 adapter that claimed to be compatible with ‘M’ and ‘B+M’ SATA SSD’s) and a SATA SSD (Silicon Power A55 M.2 SATA III). The NVMe drives couldn’t be seen by the MacBook Air, but the SATA drive worked (Restore didn’t work, but SuperDuper! does fine). Physical install is as shown.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Peel the I/O board cable up from the adhesive securing it to the fan.
I did not peel the I/O board connector, it is not needed to be peeled away securing it to the fan.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Das ging leider nicht wie beschrieben: an der Mutter links unten war eine Platine befestigt, die über den beschriebenen Sicherungsbügel ragt, so dass der nicht erreichbar war. Ohne zu wissen, ob diese Platine einfach abgeschraubt werden kann, habe ich das lieber gelassen.
Lise Lotte - 回复
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
The replacement fan's ribbon cable is a few mm longer than the original. I t will loop upwards a bit after mounting. The rubber lip on top of the old fan needs to be transferred to the new fan.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
I'm having difficulty getting the antenna connectors to snap back on. Any suggestions?
Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
Peel up the six cable loops securing the antenna cables to the upper case.
Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
Repeat this for all of the retaining loops.
The plastic loops stay with the bottom and the wires go with the top (screen).
If replacing the upper case and needing to transfer the loops to the new upper case, it is difficult to slip the loops through the slits in the new upper case. A reliable way to do this is to use a length of fishing line to pull the loops through the slits.
I used two sewing needles to get the loops back through. It is time consuming, but you can get the head of each loop through the slit with your fingers, then push on the back side of the loop with a sewing needle, hold it in place, then use a second sewing needle to push it through a little more. Once it is through a bit more, hold it on the back side with a needle, then on the front side use the sewing need to help position the loop so you can grab it with a tweezer and pull it through.
Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
These screws are extremely tight, but they'll go!
My kit didn’t come with this bit….
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
Remove the right speaker from the upper case.
Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
Remove the left speaker from the upper case.
Use the tip of a spudger to pry the microphone away from the side of the upper case.
Remove the microphone from the upper case.
Upper case remains.
This connector is different on mine and does not appear to be removeable. My replacement upper case came with it attached.
This microphone is different and glued in. Takes a bit of prying out
Don't pull too hard the microphone has the density of cardboard and I ripped mine in half.
Push/lift the keyboard ribbon cable off of the upper case with one hand.
With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
Remove the six 1.5 mm Phillips #00 screws securing the trackpad to the upper case.
Check your replacement upper case—if it doesn't have this wide T5 screw, remove it to transfer into the replacement.
I needed the #000 bit instead of #00.
wanderchic - 回复
I also needed #000.
#000 is a necessity to remove those six screws - #00 is just too thick to fit.
44等其他人完成本指南。
8条评论
I used this guide to replace the keyboard on my macbook air 11, mid 2011.
When I removed the perimeter screws on the keyboard, I then popped all of the 54 or so rivots. I bought a $34 keyboard and installed it with the perimeter screws. But then I bonded the top of each of the rivot shafts with a tiny amount of epoxy cement, after which I used a razor blade to shave each of them to be flush. After re-installing the backlight material, and reassembling the computer, it works PERFECTLY. The Apple store expert had told us that the computer could not be repaired. :-)
I’ve bought a replacement keyboard with holes in every place where a rivot existed. So it doesn’t requires any work on the case for the remains of the rivots.
Thank you very much for your clear guide! Even though I had never opened a laptop before, I was able to dig down to my keyboard with your instructions and I'm typing this now with BOTH shift keys :-D
Note: unlike @Bill Aldridge I bought extra screws to replace the rivets and replaced all but four of the rivets using (at my Father's suggestion) flat sharp wire cutters to bite into the stumps of the rivets and then pop them out.
When reassembling, you’ll probably find it easier to reconnect cables before screwing some things in (e.g. connecting the trackpad cable before screwing in the 6 phillips, or attaching the io board cables before screwing down).
All-in-all, great.
WOW just replaced my keyboard, had the faulty shift key, problem, and turning on and off was faulty. Also replaced the failing battery with a new one. I have never done this before and with these instructions, achieved this first time, with no screws left LOL. Very happy to have what feels like a new machine. Is an old Mac, but with an i5 processor, it was worth saving. Can not thank you enough.
When you say:
Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
Nerdily yours,
Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
larryleveen - 回复
The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
Michael Welham -
I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
Allen - 回复
The magnetic mat is
GERARD SZAREK -
Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
Frank O'Carroll - 回复
A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
Michael Mee - 回复
Thank you for a really smart tip! I will be using that countless more times!
Lilljedahl -
I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
AMG - 回复
The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
Hope this helps! -Dan
danielwen -
I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
Robert Hermans - 回复
Hi Robert!
Try some techniques found in this stripped screw removal guide. Good luck!
Arthur Shi -
Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
vensilver - 回复
Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
Arthur Shi -
The smaller screws went in more easily when I put back all the screws along the hinge edge first.
Rachel Slatkin - 回复
