跳转到主内容
MacBook Air 11" Mid 2011 Lower Case Replacement
你所需要的
  1. MacBook Air 11" Mid 2011 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    购买
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Lower Case Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
结论
10等其他人完成本指南。
一条评论
Super easy guide. Parts quality may vary depending on dents or other aesthetics. I recommend buying plastic feet just in case you need them and as a backup to existing inventory.
Al N - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 57
总计 13,214
