跳转到主内容
MacBook Air 11" Mid 2011 I/O Board Cable Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Air 11" Mid 2011 I/O Board Cable Replacement, I/O Board Cable: 步骤 1 中的图像 1,1
    • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
  2. MacBook Air 11" Mid 2011 I/O Board Cable Replacement: 步骤 2 中的图像 1,1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
  3. MacBook Air 11" Mid 2011 I/O Board Cable Replacement: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2011 I/O Board Cable Replacement: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
    • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
    • Remove the I/O board cable.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 980
