跳转到主内容
简介
Remove the trackpad from your MacBook AIr 11" Late 2010.
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board. Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  3. Remove the following five screws securing the battery to the upper case:
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  4. When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  5. Use the tip of a spudger to pry up the retaining flap on the trackpad data cable ZIF connector. Be careful to pry on the hinged flap, not the connector itself; the connector is delicate and may break.
    • Use the tip of a spudger to pry up the retaining flap on the trackpad data cable ZIF connector.
    • Be careful to pry on the hinged flap, not the connector itself; the connector is delicate and may break.
    • Gently slide the trackpad ribbon cable out of the ZIF connector.
  6. With one hand, lift the keyboard ribbon cable up and push it slightly away from the trackpad to access the ZIF connector underneath. Use a spudger tip to pry up the retaining flap on the keyboard ribbon cable ZIF connector. Be careful to pry on the hinged flap, not the connector itself; the connector is delicate and may break.
    • With one hand, lift the keyboard ribbon cable up and push it slightly away from the trackpad to access the ZIF connector underneath.
    • Use a spudger tip to pry up the retaining flap on the keyboard ribbon cable ZIF connector.
    • Gently slide the keyboard ribbon cable out of the ZIF connector.
  7. Remove the six 1.5 mm Phillips #00 screws that secure the trackpad assembly to the upper case.
    • Remove the six 1.5 mm Phillips #00 screws that secure the trackpad assembly to the upper case.
  8. Open the MacBook about 10 degrees. While supporting the upper case, press up on the side of the trackpad closest to the logic board. Remove the trackpad.
    • Open the MacBook about 10 degrees.
    • While supporting the upper case, press up on the side of the trackpad closest to the logic board.
    • Remove the trackpad.
结论
27等其他人完成本指南。
Andrew Optimus Goldheart
于2009年10月17日注册
479,480 信誉积分
创作了410篇指南
团队
iFixit iFixit 的会员
Community
138 名成员
创作了15,634篇指南
4条评论
I did it! Replaced the trackpad after the MacBook Air took a dive from a stand, which fortunately just shattered the trackpad's glass. Thanks for the easy to use instructions!
Just one note on step 8: I had to use a PH000 (triple 0) instead of the double 0 - almost destroyed one of the screws before realising.
Best regards,
StH
Stefan - 回复
The trackpad from my macbook air would not click anymore. The pointer still worked, i could still tap and hoover around.
My guess was that something fell between the trackpad and the housing.
And I was right, it was a bread crumb or else of a little seed.
While following this guide, I saw that a little magnet underneath the unibody is lifting the trackpad up again, after being pushed down. Right in that tiny space was the little bugger :)
I'm with Stefan, about his comment by step 8. I actually did destroy one screw (there sat really, really tight) and had to use brute force with a pincer and a tip of WD-40 to loosen it. It seems like Apple took that into account, since there are enough to leave one out :)
Peter Bakker - 回复
I had the same issue, non-clicking mouse, and a dis-assembly & light clean also sorted me out. Thanks everyone!
pabz -
Replacement went well - iFixit guide marvellous as usual and replacement trackpad performs perfectly. So good to resurrect
the trusty MB Air!
Richard Cox - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 30
总计 12,882
