跳转到主内容
MacBook Air 11" Late 2010 I/O Board Cable Replacement
你所需要的
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Late 2010 I/O Board Cable Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Late 2010 I/O Board Cable Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Late 2010 I/O Board Cable Replacement, Battery: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  3. MacBook Air 11" Late 2010 I/O Board Cable Replacement, I/O Board Cable: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  4. MacBook Air 11" Late 2010 I/O Board Cable Replacement: 步骤 5 中的图像 1,1
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 5,196
