跳转到主内容
MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement
你所需要的
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, Battery: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  3. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 1,2 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  4. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 步骤 5 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 1,2 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 2,2
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • Remove the AirPort/Bluetooth board from the Air.
结论
11等其他人完成本指南。
一条评论
Hi Andrew, thanks for your guide on MacBook Air 11" Late 2010 Airport-Bluetooth Card. I am desperately trying to purchase new cables with female connectors to connect to the Card's male jacks. I ignore the size which is important: I tried MHF 4 too small, MHF 1 too big, so before buying wrong cables again I wonder if you can tell me what size is the Card's jack connection. I thank you for your help in advance.
Max
Massimo Bazzano - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 22,961
