简介
Use this guide to replace the upper case, including the keyboard, of your MacBook Air 11" Early 2015.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
Remove the gasket from the corner nearest display cable connector.
Peel up the six cable loops securing the antenna cables to the upper case.
Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
Remove the right speaker from the upper case.
Push/lift the keyboard ribbon cable off of the upper case with one hand.
With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
11等其他人完成本指南。
5条评论
Steps 20 and 21 are necessary, as there is a logic board screw slightly hidden underneath the Wireless Card, as you can see in Step 22.
The isight cable in the top right corner: I don’t think yours is installed right, it shouldn’t be going over that rubber grommet, it should be going to the left. Your cable is all stretched. I don’t see why steps 20 and 21 would be necessary, except temporarily to remove the screw. Step 31: My inners are T9 and my outers are T10. Also, I wouldn’t rate this as a 3-bar difficult. There isn’t even anything glued in, you don’t need a heat gun or adhesive remover, no special tools besides the pentalobe bit are required. Estimated time 30-60 minutes.
I completed this process in hopes that I would have repaired a power button problem on this MacBook Air. This didn’t seem to work. Any other suggestions. Could it be the logic board? Just trying to find some answers. Wonderful step by step guide, though…Kudos to all involved.
