简介
Use this guide to replace your AirPort/Bluetooth board in the MacBook Air 11" Early 2015.
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way of the card.
7等其他人完成本指南。
一条评论
I did this with an early 2015 MacBook pro. I'm having trouble getting it to recognize all my devices. Anyone have this trouble? Is there a driver or something on the software end that I need to deal with?
Thanks
msmalljazz - 回复
