跳转到主内容
修复你的物品
维修的权力
商店
简介
Use this guide to remove the lower case.
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
结论
2等其他人完成本指南。
Sam Goldheart
于2012年10月18日注册
433,578 信誉积分
创作了547篇指南
团队
iFixit iFixit 的会员
Community
134 名成员
创作了14,684篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 16
总计 2,662
