跳转到主内容
MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix
你所需要的
  1. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix, MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 1 中的图像 1,2 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix, MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 1 中的图像 2,2
    • Unplug and shut down your laptop.
  2. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 2 中的图像 1,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 2 中的图像 2,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 2 中的图像 3,3
    • Dip a cotton swab into high-concentration isopropyl alcohol and clean the surface/surroundings of the keycap.
  3. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 3 中的图像 1,2 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 3 中的图像 2,2
    • Use a toothpick to gently remove crumbs or debris stuck in the gap between the keyboard metal and keycaps.
  4. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 4 中的图像 1,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 4 中的图像 2,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 4 中的图像 3,3
    • Gently use the toothpick to pry up sticky key(s) from the bottom of the keycaps.
  5. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 5 中的图像 1,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 5 中的图像 2,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 5 中的图像 3,3
    • Remove the 2 plastic key carrier parts using tweezers.
    • Use tweezers to grab one side of the tip (circled in orange) of the carrier parts and pull it out. Do the same thing on the other side of the tip.
  6. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 6 中的图像 1,1
    • Use cotton swabs with damp with high-concentration isopropyl alcohol to clean the part underneath the key carriers.
  7. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 7 中的图像 1,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 7 中的图像 2,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 7 中的图像 3,3
    • Put dish soap and warm water in a cup and soak the 2 key carriers in the cup for 10 min.
    • Stirring may help.
  8. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 8 中的图像 1,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 8 中的图像 2,3 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 8 中的图像 3,3
    • Let the carrier parts dry on a tissue paper.
    • Use The Super Lube LightWeight Synthetic Oil to lube the 2 carriers before assembling them, especially the parts that contact with other parts.
  9. MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 9 中的图像 1,2 MacBook Air & MacBook Pro (Newer than 2019) Sticky Key Fix: 步骤 9 中的图像 2,2
    • Reinstall everything and pop up the keycaps.
    • When the keycaps are reinstalled, slide them to the top of the keycap first, then press down the bottom part until you hear a "click."
结论
Tan
于04/15/24注册
169 声望
撰写一个指南
团队
UC Davis, Team 2-6, Morris Spring 2024 UC Davis, Team 2-6, Morris Spring 2024 的会员
UCD-MORRIS-S24S2G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 45
总计 104
