简介
如果您的MacBook不再保修,或者插入时看不到橙色或绿色充电指示灯,请检查电源线是否有损坏。
在本指南中,我们将更换充电器连接到 MacBook 的线。
或者,您可以使用How to Repair an Apple AC Adapter Broken Cable修复现有的电缆,而不是替换它。
你所需要的
打开绕线小翅膀的电线处。
用吹风机加热电源的塑料外壳,和/或沿外壳的两半之间的接缝移动刀片,以减弱粘合剂。 这样可以更容易地撬开。
插入你的钳子并慢慢撬。 (确保他们保持在内角,否则可能会伤到自己或者捣毁电源。)
绕线小翅膀将调出来
在另一边做同样的步骤。
慢慢操作!
向所有您的朋友申请并重覆有问题的电缆的受害者;-)
180等其他人完成本指南。
由衷感谢以下译者:
94%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
49条评论
This guide was very helpful in figuring out what needed to be done and how to do it. I don't have access to a lead pump so I ended up removing the old wires and then soldering the new ones on top of the remaining solder. So far it's working just fine!
I wasn't able to open my charger, even when using heat, the pliars as shown here and even a knife. As the damage to my cable was a few inches from the charger I just cut the cord and soldered a new one to the end. Cable looks a bit ratty but you could use white tubing to place over the top.
This guide is great and would definitely use it if possible =)
Try using bench vise with needle-nose plier
ridwan -
You certainly need to knife thoroughly along the seam for it to open; after which you need to pry slowly with a pair of pliers by applying a considerable amount of force. Prudence is necessary when applying force because brute force will likely damage the casing; that means if you think adding more force will break the casing, it probably will. Knife it some more and then try again. Patience is *key*.
nawkwan -
I managed to open the casing without breaking it *but I did break my pliers in the process. lol
nawkwan -
