跳转到主内容
Mac mini Model A1283 Top Housing Replacement
你所需要的
  1. Mac mini Model A1283 Top Housing Replacement, Top Housing: 步骤 1 中的图像 1,2 Mac mini Model A1283 Top Housing Replacement, Top Housing: 步骤 1 中的图像 2,2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini Model A1283 Top Housing Replacement: 步骤 2 中的图像 1,3 Mac mini Model A1283 Top Housing Replacement: 步骤 2 中的图像 2,3 Mac mini Model A1283 Top Housing Replacement: 步骤 2 中的图像 3,3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini Model A1283 Top Housing Replacement: 步骤 3 中的图像 1,2 Mac mini Model A1283 Top Housing Replacement: 步骤 3 中的图像 2,2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1283 Top Housing Replacement: 步骤 4 中的图像 1,2 Mac mini Model A1283 Top Housing Replacement: 步骤 4 中的图像 2,2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1283 Top Housing Replacement: 步骤 5 中的图像 1,2 Mac mini Model A1283 Top Housing Replacement: 步骤 5 中的图像 2,2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1283 Top Housing Replacement: 步骤 6 中的图像 1,2 Mac mini Model A1283 Top Housing Replacement: 步骤 6 中的图像 2,2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
结论
20等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 42
总计 20,123
