跳转到主内容
Mac mini Model A1176 Top Housing Replacement
你所需要的
  1. Mac mini Model A1176 Top Housing Replacement, Top Housing: 步骤 1 中的图像 1,2 Mac mini Model A1176 Top Housing Replacement, Top Housing: 步骤 1 中的图像 2,2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    A spackle knife makes these steps go much faster.
    jouniseppanen - 回复
    A double sided letter opener or a thin non-serrated butter knife will suffice.
    To prenent cosmetic blemishes, place a matchbook cover or similar thin cardboard on the outer perimeter under the “jimmy”.
    Mike - 回复
  2. Mac mini Model A1176 Top Housing Replacement: 步骤 2 中的图像 1,3 Mac mini Model A1176 Top Housing Replacement: 步骤 2 中的图像 2,3 Mac mini Model A1176 Top Housing Replacement: 步骤 2 中的图像 3,3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Patience is your best friend.
    Do not insert “jimmy in too far. Marking a line from tip upwards on the tool will prevent too far insertion, possibly breaking tabs or damaging internal components.
    To prevent the cover closing back up, small strips of matchbook cover (os equivalent) can be inserted about half inch hold prevent closure.
    Mike - 回复
  3. Mac mini Model A1176 Top Housing Replacement: 步骤 3 中的图像 1,2 Mac mini Model A1176 Top Housing Replacement: 步骤 3 中的图像 2,2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 Top Housing Replacement: 步骤 4 中的图像 1,2 Mac mini Model A1176 Top Housing Replacement: 步骤 4 中的图像 2,2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 Top Housing Replacement: 步骤 5 中的图像 1,2 Mac mini Model A1176 Top Housing Replacement: 步骤 5 中的图像 2,2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 Top Housing Replacement: 步骤 6 中的图像 1,2 Mac mini Model A1176 Top Housing Replacement: 步骤 6 中的图像 2,2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Before reassembly, make sure no wires are sticking out.
    Line up top cover carefully. Gently press down on top cover until top and bottom fully seated.
    CAUTION! DO NOT PRESS TOO HARD ON THE COVER TO PREVENT CRACKING THE PLASTIC TOP.
    GO EASY.
    Mike - 回复
结论
47等其他人完成本指南。
2条评论
Does this work to remove a disc
ajunelady6 - 回复
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 73
总计 30,577
