简介
Remove the top housing to access your mini's internals.
你所需要的
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
50等其他人完成本指南。
2指南评论
Does this work to remove a disc
ajunelady6 - 回复
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
