简介
Prerequisite only.
你所需要的
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
在这个步骤中使用的工具:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
终点
另外一个人完成了本指南。
