本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace the optical drive cable if the connector is broken or the ribbon cable itself is damaged.
你所需要的
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 or T9 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
Remove the following three screws:
One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
One 16.2 mm T6 Torx screw
One 26 mm T6 Torx standoff
在这个步骤中使用的工具:Mac mini Logic Board Removal Tool
Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
Slightly lift the small plastic strip spanning the width of the optical drive.
Carefully de-route the free end of the optical drive connector out from under the optical drive bracket.
6等其他人完成本指南。
