跳转到主内容
Mac mini Late 2014 PCIe SSD Cable Replacement
你所需要的
  1. Mac mini Late 2014 PCIe SSD Cable Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 2 中的图像 1,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 2 中的图像 2,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 3 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 3 中的图像 2,2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 PCIe SSD Cable Replacement, Antenna Plate: 步骤 4 中的图像 1,1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 5 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 5 中的图像 2,2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 7 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 7 中的图像 2,2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 8 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 8 中的图像 2,2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 9 中的图像 1,1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 PCIe SSD Cable Replacement, SSD: 步骤 10 中的图像 1,1
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 11 中的图像 1,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 11 中的图像 2,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 11 中的图像 3,3
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 12 中的图像 1,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 12 中的图像 2,3 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 12 中的图像 3,3
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
  13. Mac mini Late 2014 PCIe SSD Cable Replacement, PCIe SSD Cable: 步骤 13 中的图像 1,1
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  14. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 14 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 14 中的图像 2,2
    • Remove the PCIe SSD cable bracket.
  15. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 15 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to lift the PCIe SSD connector straight up off of its connector on the logic board.
    • Be careful not to pry up on the socket itself.
  16. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 16 中的图像 1,2 Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 16 中的图像 2,2
    • Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
  17. Mac mini Late 2014 PCIe SSD Cable Replacement: 步骤 17 中的图像 1,1
    • Remove the PCIe SSD cable from the Mac mini.
结论
29等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,086 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
8指南评论
Where i can buy the PCIe SSD card?
melvin suarez - 回复
Where i can buy the PCIe SSD card, someone?
Claudio Vargas - 回复
I can supply these cables. Please reply to this thread.
Thomas Hall -
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
Angelo - 回复
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
Daniel Abdulla -
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 82
过去 30 天: 447
总计 63,143
