跳转到主内容
Mac mini Late 2014 Hard Drive Cable Replacement
你所需要的
  1. Mac mini Late 2014 Hard Drive Cable Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 2 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 2 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 3 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 3 中的图像 2,2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Hard Drive Cable Replacement, Antenna Plate: 步骤 4 中的图像 1,1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 5 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 5 中的图像 2,2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 7 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 7 中的图像 2,2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 8 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 8 中的图像 2,2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 9 中的图像 1,1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 Hard Drive Cable Replacement, Fan Assembly: 步骤 10 中的图像 1,1
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
  11. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 11 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 11 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 11 中的图像 3,3
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 12 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 12 中的图像 2,2
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  13. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 13 中的图像 1,1
    • Remove the fan from the Mac mini.
  14. Mac mini Late 2014 Hard Drive Cable Replacement, Logic Board Assembly: 步骤 14 中的图像 1,1
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  15. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 15 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 15 中的图像 2,2
    • Remove the SATA cable connector bracket.
  16. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 16 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 16 中的图像 2,2
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  17. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 17 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 17 中的图像 2,2
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  18. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 18 中的图像 1,1
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  19. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 19 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 19 中的图像 2,2
    • Remove the PCIe SSD cable bracket.
  20. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 20 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 20 中的图像 2,2
    • Lift the PCIe SSD connector up off its socket.
  21. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 21 中的图像 1,1
    • Remove the single 16 mm T6 screw securing the logic board.
  22. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 22 中的图像 1,1
    在这个步骤中使用的工具:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  23. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 23 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 23 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 23 中的图像 3,3
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  24. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 24 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 24 中的图像 2,2
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  25. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 25 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 25 中的图像 2,2
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  26. Mac mini Late 2014 Hard Drive Cable Replacement, Power Supply: 步骤 26 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement, Power Supply: 步骤 26 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement, Power Supply: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    • The AC-in socket is secured with a small metal retaining clip.
    • Use tweezers or your fingers to pull the clip away from the AC-in socket, and remove it from the Mac mini.
    • When replacing the clip, push it in until it stops—it should be secure even if there is no audible click.
  27. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 27 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 27 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 27 中的图像 3,3
    • To free the power supply from the case, grab the AC-In connector, which acts like a latch.
    • Rotate the AC-In connector 90 degrees counter-clockwise.
  28. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 28 中的图像 1,1
    • The AC-In latch should fit into the groove above it in the case.
    • During reassembly ensure the power supply is inserted far enough into the case that the latch will engage with the groove.
  29. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 29 中的图像 1,1
    • Remove the 8 mm T6 screw securing the power supply.
  30. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 30 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 30 中的图像 2,2
    • Slide the power supply out of the mini, minding any cables that may get caught.
  31. Mac mini Late 2014 Hard Drive Cable Replacement, Drive Tray Assembly: 步骤 31 中的图像 1,1
    • Remove the single 8 mm T6 screw securing the drive tray.
  32. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 32 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 32 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 32 中的图像 3,3
    • Lift the drive tray up out of the Mac mini.
  33. Mac mini Late 2014 Hard Drive Cable Replacement, Hard Drive Assembly: 步骤 33 中的图像 1,2 Mac mini Late 2014 Hard Drive Cable Replacement, Hard Drive Assembly: 步骤 33 中的图像 2,2
    • Remove the four (two on each side) 6.5 mm T8 screws securing the hard drive to the drive tray.
  34. Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 34 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 34 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement: 步骤 34 中的图像 3,3
    • Lift the hard drive up and remove it from the drive tray.
    • During reassembly, be sure to thread the hard drive cable through the slot in the drive tray.
  35. Mac mini Late 2014 Hard Drive Cable Replacement, Hard Drive: 步骤 35 中的图像 1,3 Mac mini Late 2014 Hard Drive Cable Replacement, Hard Drive: 步骤 35 中的图像 2,3 Mac mini Late 2014 Hard Drive Cable Replacement, Hard Drive: 步骤 35 中的图像 3,3
    • Lift up the ribbon cable and carefully peel away the black tape underneath. It secures the SATA cable connector to the PCB of the hard drive. Failing to remove the tape will almost surely cause the contacts soldered to the flex cable to rip from the connector housing, as the retention force of the contacts in the housing is quite low.
    • Pull the SATA cable connector straight out of the hard drive.
    • Carefully peel off the two black, square-shaped sticky pads (one visible in picture) from the corners of the hard drive, and stick them to your new hard drive in the same locations.
结论
29等其他人完成本指南。
Sam Goldheart
于10/18/12注册
474,950 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,620篇指南
1指南评论
great , thank-you for help me
Francesco Grassi - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 47
过去 30 天: 222
总计 33,170
