简介
Noisy or poorly-performing fan? Use this guide to replace the fan, or remove it for cleaning in your Mac mini Late 2014.
你所需要的
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
23等其他人完成本指南。
4条评论
Had a problem with a noisy fan. Apparently the blades were scratching its housing, so i just bend the aluminium housing a bit and spin the fan to see if its still had a contact. It works like a charm.
Just got my first ever Mac yesterday, used it all day without realizing the fan wasn't working. Opened it up this morning to find the fan completely unplugged from the board. Plugged it back in and now it's working great! Thanks so much!
I have a Mac mini without a fan. The plug is also not there, so it is a version, 2.6 GHz, without a fan. (and I almost bought one as the vendor said that error is displayed propably, but I started it without any error message).
