简介
Problems with Wi-Fi or Bluetooth? You may have a faulty AirPort card. Use this guide to replace the AirPort card in your Mac mini Late 2014.
你所需要的
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
16等其他人完成本指南。
4条评论
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - 回复
