简介
How to remove the upper case.
你所需要的
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
12等其他人完成本指南。
附加文件
2指南评论
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
No, I didn’t think the Jimmy is expensive or too small.
And the Jimmy didn’t break something so it is the best solution I think!
