跳转到主内容
Mac mini (PowerPC) Upper Case Replacement
你所需要的
  1. Mac mini (PowerPC) Upper Case Replacement, Top Housing: 步骤 1 中的图像 1,2 Mac mini (PowerPC) Upper Case Replacement, Top Housing: 步骤 1 中的图像 2,2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini (PowerPC) Upper Case Replacement: 步骤 2 中的图像 1,3 Mac mini (PowerPC) Upper Case Replacement: 步骤 2 中的图像 2,3 Mac mini (PowerPC) Upper Case Replacement: 步骤 2 中的图像 3,3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini (PowerPC) Upper Case Replacement: 步骤 3 中的图像 1,2 Mac mini (PowerPC) Upper Case Replacement: 步骤 3 中的图像 2,2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini (PowerPC) Upper Case Replacement: 步骤 4 中的图像 1,2 Mac mini (PowerPC) Upper Case Replacement: 步骤 4 中的图像 2,2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini (PowerPC) Upper Case Replacement: 步骤 5 中的图像 1,2 Mac mini (PowerPC) Upper Case Replacement: 步骤 5 中的图像 2,2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini (PowerPC) Upper Case Replacement: 步骤 6 中的图像 1,2 Mac mini (PowerPC) Upper Case Replacement: 步骤 6 中的图像 2,2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
结论
12等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2条评论
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
spatula - 回复
No, I didn’t think the Jimmy is expensive or too small.
And the Jimmy didn’t break something so it is the best solution I think!
Toni Makkaroni -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 46
总计 11,573
