简介
No signal to Bluetooth? Replace the antenna.
配件
无需配件。
  1. Power down your Mac mini, disconnect all of the cables, and flip it over. Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Once you have the first side free, rotate the Mac mini and start prying up on the front edge. Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Keep working around the perimeter, freeing the clips along the final edge. Keep working around the perimeter, freeing the clips along the final edge.
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  7. Flip the Mac mini back over and lift the top housing off of the lower housing. Flip the Mac mini back over and lift the top housing off of the lower housing.
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  8. If your mini does not have Airport installed, then skip this step.
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  9. Remove the yellow tape securing the power button cable to the black plastic framework.
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  10. Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  11. Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  12. If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  13. Remove the single silver Phillips screw from the black plastic framework directly below the Bluetooth antenna board.
    • Remove the single silver Phillips screw from the black plastic framework directly below the Bluetooth antenna board.
  14. Remove the yellow tape securing the Bluetooth antenna cable to the black plastic framework.
    • Remove the yellow tape securing the Bluetooth antenna cable to the black plastic framework.
    • Deroute the Bluetooth antenna cable.
    • Lift the silver Bluetooth antenna board out of its slot.
结论
4等其他人完成本指南。
附加文件
iRobot
于2009年09月24日注册
1 信誉积分
创作了623篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 13
总计 11,521
