跳转到主内容
Mac mini (PowerPC) Modem Replacement
你所需要的
  1. Mac mini (PowerPC) Modem Replacement, Top Housing: 步骤 1 中的图像 1,2 Mac mini (PowerPC) Modem Replacement, Top Housing: 步骤 1 中的图像 2,2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini (PowerPC) Modem Replacement: 步骤 2 中的图像 1,3 Mac mini (PowerPC) Modem Replacement: 步骤 2 中的图像 2,3 Mac mini (PowerPC) Modem Replacement: 步骤 2 中的图像 3,3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini (PowerPC) Modem Replacement: 步骤 3 中的图像 1,2 Mac mini (PowerPC) Modem Replacement: 步骤 3 中的图像 2,2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini (PowerPC) Modem Replacement: 步骤 4 中的图像 1,2 Mac mini (PowerPC) Modem Replacement: 步骤 4 中的图像 2,2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini (PowerPC) Modem Replacement: 步骤 5 中的图像 1,2 Mac mini (PowerPC) Modem Replacement: 步骤 5 中的图像 2,2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini (PowerPC) Modem Replacement: 步骤 6 中的图像 1,2 Mac mini (PowerPC) Modem Replacement: 步骤 6 中的图像 2,2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini (PowerPC) Modem Replacement, Mass Storage Unit: 步骤 7 中的图像 1,1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  8. Mac mini (PowerPC) Modem Replacement: 步骤 8 中的图像 1,1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  9. Mac mini (PowerPC) Modem Replacement: 步骤 9 中的图像 1,1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  10. Mac mini (PowerPC) Modem Replacement: 步骤 10 中的图像 1,1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  11. Mac mini (PowerPC) Modem Replacement: 步骤 11 中的图像 1,1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  12. Mac mini (PowerPC) Modem Replacement, Modem: 步骤 12 中的图像 1,1
    • Remove the two silver Phillips screws from the corners of the modem board.
  13. Mac mini (PowerPC) Modem Replacement: 步骤 13 中的图像 1,1
    • Pull the modem up from its connector. If it sticks, just wiggle it back and forth a bit as you pull up.
  14. Mac mini (PowerPC) Modem Replacement: 步骤 14 中的图像 1,1
    • Disconnect the RJ-11 cable from the back of the modem.
结论
2等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 5,510
