跳转到主内容
Mac Pro Late 2013 SSD Replacement
你所需要的
  1. Mac Pro Late 2013 SSD Replacement, Outer Case: 步骤 1 中的图像 1,2 Mac Pro Late 2013 SSD Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 SSD Replacement: 步骤 2 中的图像 1,3 Mac Pro Late 2013 SSD Replacement: 步骤 2 中的图像 2,3 Mac Pro Late 2013 SSD Replacement: 步骤 2 中的图像 3,3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 SSD Replacement, SSD: 步骤 3 中的图像 1,1
    • Remove the single 6.5 mm T8 Torx screw.
  4. Mac Pro Late 2013 SSD Replacement: 步骤 4 中的图像 1,3 Mac Pro Late 2013 SSD Replacement: 步骤 4 中的图像 2,3 Mac Pro Late 2013 SSD Replacement: 步骤 4 中的图像 3,3
    • Pull the SSD slightly away from the graphics card.
    • Do not pull the top edge of the SSD more than 1/2" away from the graphics card, or you will risk damaging it.
    • Lift the SSD straight up out of its slot on the graphics card.
结论
40等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,734篇指南
8条评论
Will a 970 evo 512 gb pcie m2 fit on here?
Sam Yao - 回复
As long as the drive is not the Plus version, you may be able to use an adapter in order to use that SSD in your MacPro6,1:
https://www.amazon.com/Sintech-Adapter-U...
I have not tried this, but am, currently, researching a fix for a machine in my care.
Robert Maxwell -
Yes—works very well with the Sintech adaptor (and even with an EK-M.2 NVMe Heatsink — use thermal paste for longevity!).
Just did this yesterday and it’s a great/fast/easy upgrade.
ericbalog -
Do you need a heat sink in the SSD?
Cesar Cuenca - 回复
The stock (Samsung) drive(s) that shipped (from Apple) with these machines do not; unless the black, outer covering helps with heat. [???]
I have had both a Samsung MZ-JPU256T/0A1 (256GB) and Samsung MZ-KPU1T0T/0A1 (1TB) installed in my machine without issue.
Third-party drives may include or heatsink and/or require at least 10.13 (High Sierra).
Robert Maxwell -
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 161
过去 30 天: 903
总计 81,227
