当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
The fan assembly is attached to the rest of the computer by two cables on the IO board side.
Tilt the assembly up away from the IO board.
Do not try to remove the fan assembly yet, as it is still attached by two cables.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
