跳转到主内容
Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock
你所需要的
  1. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Remove Enclosure: 步骤 1 中的图像 1,1
    • Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
  2. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Remove screws on retainer plate: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $9.99
    购买
    • Using a T5 screwdriver, remove the six screws retaining the latch on the inside of the enclosure and lift out the retainer plate.
  3. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Replace latch with modified version: 步骤 3 中的图像 1,1
    • Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
  4. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Install Cable Lock: 步骤 4 中的图像 1,1
    • Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
结论
This guide will help you secure your Mac Pro (2013) with any cable lock.
另外一个人完成了本指南。
Kemper Barkhurst
于07/30/15注册
149 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 2,580
