跳转到主内容
配件
没有特定配件。
  1. Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  2. Lift and remove the metal cover from the AirPort board bay.
    • Lift and remove the metal cover from the AirPort board bay.
  3. Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector. Remove the fan assembly ribbon cable from its ZIF socket. Remove the fan assembly ribbon cable from its ZIF socket.
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  4. Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable. Disconnect the fan ribbon cable. Disconnect the fan ribbon cable.
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
结论
Andrew Optimus Goldheart
于2009年10月17日注册
472,735 信誉积分
创作了410篇指南
团队
iFixit iFixit 的会员
Community
137 名成员
创作了16,056篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 54
