跳转到主内容
加入维修社区 - 创建账户
Mac Pro Late 2013 AirPort Antenna Array Replacement
你所需要的
  1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: 步骤 1 中的图像 1,2 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 2 中的图像 1,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 2 中的图像 2,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 2 中的图像 3,3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 步骤 3 中的图像 1,3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 步骤 3 中的图像 2,3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 步骤 3 中的图像 3,3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 4 中的图像 1,2 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 4 中的图像 2,2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 5 中的图像 1,1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 7 中的图像 1,2 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 8 中的图像 1,1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 步骤 9 中的图像 1,3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 步骤 9 中的图像 2,3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 步骤 9 中的图像 3,3
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: 步骤 10 中的图像 1,1
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 11 中的图像 1,1
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 12 中的图像 1,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 12 中的图像 2,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 12 中的图像 3,3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 13 中的图像 1,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 13 中的图像 2,3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 13 中的图像 3,3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: 步骤 14 中的图像 1,1
    • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
  15. Mac Pro Late 2013 AirPort Antenna Array Replacement: 步骤 15 中的图像 1,1
    • Remove the AirPort antenna array.
结论
3等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,373篇指南
2指南评论
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - 回复 分享
is bluetooth module part of (inside) airport board?
Sanong - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 69
总计 6,522
