简介
Use this guide to replace the AC power socket in your Mac Pro.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
你所需要的
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
Remove the two 9 mm silver T10 Torx screws securing the IO Board to the IO shield.
Remove the four 6.5 mm T4 screws (with washers) from the flange around the AC socket.
4等其他人完成本指南。
